Compra de Aérografo
The_Command
Compra de Aérografo
Post by The_Command » Sat Mar 26, 2011 5:31 pm
Bem já que consegui adquirir um compressor de pintura, agora falta-me o aérografo.
Alguém me pode dar uma ajuda na compra de um, pois não entendo nada daquilo, já andei a ver uns no ebay.
De momento pretendo gastar até 50€, sei que provavelmente não irei comprar nenhum ferrari mas pronto pra agora só posso gastar mesmo isso.
Re: Compra de Aérografo
Post by Bucov » Sun Mar 27, 2011 1:28 am
Dá uma vista de olhos aqui:
http://www.hobbiesguinea.com/product_in ... d96141f344" onclick="window.open(this.href);return false;
Image Image
The_Command
Post by The_Command » Sun Mar 27, 2011 3:37 pm
Obrigado pela ajuda.
Mas ontem tinha licitado um no Ebay e confirmei agora que ganhei o leilão custou-me 16.00€ com portes, não sei se será bom mas logo se vê.
Item NO. : WD-130E
Specifications:
Condition: New In Box
Feed Type: Gravity
Dual-Action Trigger Air/Fluid Control
Nozzle Dia : 0.3mm
Fluid Cup: 7CC
Working Pressure: 15-50PSI
Spray Pattern: Hairline to 100mm
Applications:
Illustration, Fine/Commercial Art, Photo Retouching, Custom Automotive, Motorcycle Graphics, Nails & Cosmetics, Miniatures, Taxidermy / Lures, Models/RC'S/Trains. Hobbies and Crafts.
Spray and Color Media:
Watercolors, Acrylics, Inks and Dyes, Automotive Urethanes, Lacquers and Enamels
How to Spray:
1. Fill fluid in the cup after thinning appropriately.
2. Hold the airbrush lightly in your hand.
3. By pressing the main lever, a stream of air emerges. Then draw it backward gradually for color atomization.
4. The spray pattern is in accordance with water or solvent by a brush.
5. For fine line spray, remove the needle cover and hold the airbruch near a work surface.
How to clean:
1. Empty the fluid cup and wash with water or solvent by a brush.
2. Refill cup with water or solvent, then block the needle cover with finger and spray. The air flows backward into nozzle to clean the paints remained the airbrush.
