Nissan R 390 Tamiya
Luca
Nissan R 390 Tamiya
Mensagem por Luca »
Bom pessoal, como a Ferrari está praticamente no final e a bancada não pode ficar vazia, vamos a mais uma montagem.
Antes de iniciar, veremos um pouco sobre o carro e algumas referências:
"The R390 GT1 is equipped with a VRH35L engine. People who are familiar with motor racing will recognize this engine. The engine in the R90 CP, which obtained a pole position in the 1990 Le Mans race (and unfortunately lost to the Jaguar designed by this year's designer of the R390, Tony Southgate), was a VRH35Z engine. After competing in the 1990 Le Mans race, the car sporting the same engine went on to win the Daytona 24-hour race two years later. Since 1993, when the JSPC broke up and racing with V8 engines was cancelled, a soon return is desired with continued development only at this stage.
The development of the R390 was much shorter than commonly thought. At the shakedown test at Estoril, all of the drivers praised the performance of the engine, saying that it was easy to handle and possessed great power. Its brilliant achievement of securing a pole position in the pre- qualifying race underlines the fact that it is an advanced engine.
When development of the R390 GT1 began last year, there were a number of engines to choose from. The first was an in- line 6-cylinder RB26 DETT which was used in the 1995 and 1996 Le Mans races. The second was a V8 engine more advanced than that found in Group C cars and at the heart of future race car engines. The third choice was a totally new type of engine.
Because of the lack of development time, the third choice was dropped. But the selection between the RB and V8 engines was slow because the maximum engine output is the same as that of engines with regulations limited by the restrictor. The V8 engine was finally chosen for the following three reasons.
In modern race cars which use the engine as a stress member of the chassis, a shorter, wider V8 engine would provide more efficient chassis durability.
The shorter V8 engine reduces the Z axle rotation time and improves turn-in.
The cylinder block of the VRH35 is aluminum as opposed to the cast steel model of the RB26 DETT. There is a 20 kg difference in weight. It is possible to use a heavier material for greater body durability.
In the redesigning of the engine, the VRH35L was based on the VRH35Z with an emphasis on the regulation of air flow volume from the restrictor instead of a fuel regulation, which was important at the time the VRH35Z was in use. Design modifications were made to the intake and exhaust system, the major movement system, and the cooling system, all involved with increasing the combustion efficiency and combustion pressure.
In a 24-hour endurance race, reliability and durability are as important as, or even more important than, output characteristics. A computer-controlled engine testing device (as seen on a TV commercial) that simulates the conditions at the Sarthe Circuit completed a 30-hour continuous test while improvements in the endurance reliability of the actual car will continue until the start of the race. "
Este é carro de rua... Muito bonito por sinal... principalmente a cor.
E está será a minha referência....
Começando por tapar alguns buracos.... e como tem marcas de injeção... a Tamiya realmente caprichou neste péssimo ponto. :evil:
E haja marcas no chassis também...
Por enquanto é isso.
Luca.
Luca
Re: Nissan R 390 Tamiya
Mensagem por Luca »
Dando continuidade....
Nada melhor que testar tudo antes da montagem propriamente dita... então fiz uma pré-montagem completa... os encaixes são tão bons que permitem fazer isso sem praticamente nenhuma cola.
Chassis, Cockpit e motor..
Aproveitei a brincadeira para começar a aplicar Fibra de Carbono no chassis...
Aproveitei a força e comecei a aplicar os Decais no carro...
Depois tem mais...
Luca.
EPÁ ISTO É QUE É TRABALHAR :mrgreen: :mrgreen:
Se o Socrates (Primeiro Ministro) sabe desta produtividade, ainda te vai ai buscar :mrgreen:
Luca
Mensagem por Luca »
Obrigado pelos comentários. :mrgreen:
Um amigo me alertou que inverti a posição do Aerofólio :shock: :evil: a solução vai ser inverter o aerofólio ou recortar as laterais (já estão soldadas e não sei se será viável)... o grande problema vai ser o decal... já que o nome Nissan fica virado para o carro, ou seja, se inverter irá ficar errado. Mas vamos ver no que vai dar...
O Monocoque do carro recebe Fibra de Carbono em alguns lugares e Kevlar no banco. Como algumas peças vem injetadas e iriam dificultar a aplicação, resolvi fazer um corte e retirar essas peças para poder detalhar melhor.
As peças no lugar...
Mas precisamos fechar o local...
Usei um cartão velho de Chip para celular...
Acabamento...
Aqui como ficará o local...
As rodas receberam Wash e os parafusos de engate rápido foram pintados...
Fiz um DryBrush diferente no braço de suspensão... gostei do resultado...
Chassis com Fibra aplicada, escurecido com Smoke e um pouco de "pó" feito com Preto fosco...
Ainda preciso dar acabamento neste furo... esqueci de terminar de abrir...
Apliquei BareMetal para simular a manta de proteção e um pouco de Betume para simular o aquecimento...
Motor com suas partes distintas pintadas...
Bom.. depois tem mais coisa...
Luca.
Luca,
Parabens pelos teus trabalhos. Tenho visto com atencao estes ultimos, todos estao com um excelente nivel!
Gostava de ver um carro de rally feito por ti... acho que so te deve faltar mesmo isso... um bom desafio nao?
Cumps
Luca
Mensagem por Luca »
Evolution VI,
Obrigado por acompanhar meus trabalhos. Ainda tenho muito que aprender (afinal são somente 2 anos de modelismo), mas tenho montado muitos carros e aprendido um pouquinho em cada um deles.
Pra falar a verdade a única coisa que me falta nos carros é montar F-1. Rally já montei 2 Subarus (particularmente são os carros que mais gosto...).
Aqui os 2 carros que montei...
Luca.
Boas Luca,
Sao apenas 2 anos de modelismo mas ja carregas muita experiencia. Estes 2 subarus estao um mimo! :D Parabens!
Eu deixava o Subaru de asfalto limpinho... mas deixa la, ele tambem fica muito bem assim.
Desafiava-te a contruir um Evo... que dizes?
Abraco!
Luca
Mensagem por Luca »
Seguindo com a atualização...
Conforme referência, os discos de freio possuem 2 tonalidades.... então uma máscara foi feita para receber a outra cor..
Resultado...
O inteiror... Precisei fazer alguns botões com Spure pois no Kit eles não haviam... assim como o sistema de telemetria do carro...
Carroceria...
Pintada, envernizada e polida. Ainda falta um polimento final para dar o brilho e tirar as manchas de dedo...
Motor.... vamos continuando a adicionar a mecânica do carro... e fiz alguns Washs..
Falta aplicar os Decais nos Discos de freio...
Testando os encaixes com motor e carroceria...
Tudo fecha perfeitamente bem... só necessitando uma forcinha para fechar por completo...
Luca.
Ta a ficar excelente mesmo!
Olha, que mescara foi essa que utilizaste nos discos?
Abraco
Luca
Mensagem por Luca »
Foi esta aqui:
Mr. Hobby - Mr. Masking Sol Neo Scale
Luca.
Espectaculo!
Isso quanto custa?
rosso corsa
Mensagem por rosso corsa »
Excelente trabalho Luca, os meus parabéns =D> =D>
Gostei principalmente das diferentes tonalidades que consegues dar ás peças do compartimento do motor, excelente.
Luca
Mensagem por Luca »
Evo,
Fica complicado falar em preço... já que estamos em países diferentes, principalmente no que se refere à moeda corrente.
Aqui no Brasil está em torno de uns R$ 20 reais, o que em Euros deve estar custando algo próximo entre 6 e 8 Euros.
Luca
Mensagem por Luca »
rosso corsa,
Obrigado pelos comentários. Esse Kit é muito prazeroso de se montar.
A princípio, rosso corsa é a cor mais bonita da Ferrari :mrgreen: :lol: :mrgreen:
Lu.ca
